CSM Denny
#1 Posted : Tuesday, December 13, 2011 5:28:47 AM(UTC)
CSM Denny
I am new to Forum which I am finding very difficult to use. I called help desk only to find someone from another country I could not understand. I have a Maytag 9600 SQ0 and I have a problem with the control panel sensing light will not go off and dryer will not start. Last year I had the control panel replace and a thermostat put in. A couple of months later the clothes on delicate cycle were very hot. This lasted a month or two and now the sensing light will not go off and dryer will not start. I assume I need a new control panel and some type of temperature control.
Does anyone have any suggestions?
ApplianceJunk
#2 Posted : Tuesday, December 13, 2011 5:49:34 AM(UTC)
ApplianceJunk
You need to do the troubleshooting test that can be found in the tech sheet for your model dryer.
Here is a copy of the tech sheet for your model.
http://appliancejunk.com...wnloads;sa=view;down=402
Is this maytag epic dryer worth fixing (Dryer Repair)
by hsshanholtz@gmail.com 3/19/2017 8:35:13 AM(UTC)
Maytag Epic Dryer stops mid cycle on auto (Dryer Repair)
by sjacobs4 12/10/2013 10:20:06 AM(UTC)
