rjm5
#1 Posted : Sunday, December 11, 2011 12:37:33 PM(UTC)
rjm5
whirpool electric dryer is 6 years old It stopped heating-everything else works although the timer will go down but when it gets to cooldown setting it will not go any further to shut off and just keeps running
ApplianceJunk
#2 Posted : Sunday, December 11, 2011 12:46:15 PM(UTC)
ApplianceJunk
Could you post the model number for me?
Thanks,
rjm5
#3 Posted : Sunday, December 11, 2011 1:04:02 PM(UTC)
rjm5
LER6620PQ0
Again it will not heat at all it tumbles fine -the timer will go down and stop at cool down but will not advance to shut off
ApplianceJunk
#4 Posted : Sunday, December 11, 2011 1:11:43 PM(UTC)
ApplianceJunk
I would check #9 thermal cut-off in this diagram for your model dryer.
Check it for continuity with a ohm meter. If it's open or has no continuity then it needs to be replaced.
Same with the heating element, check it for continuity with a ohm meter.
Bulkhead parts replacement parts for WHIRLPOOL LER6620PQ0 29"ELECTRIC DRYER | AppliancePartsPros.com
rjm5
#5 Posted : Sunday, December 11, 2011 2:01:03 PM(UTC)
rjm5
any idea if i need these replaced what i am looking at total cost for repairman to come to home
Whirpool Dryer Not Drying (Dryer Repair)
by hales1234 2/25/2015 7:22:18 AM(UTC)
WHirpool Dryer not staying hot (Dryer Repair)
by kappie 8/31/2014 9:24:00 AM(UTC)
Whirpool Dryer buzzing. (Dryer Repair)
by jv9908 8/21/2013 9:12:16 PM(UTC)
Whirpool Dryer seems too hot (Dryer Repair)
by Scorpions 8/17/2012 1:28:22 AM(UTC)
Whirpool Dryer Heats up initial then don't restart (Dryer Repair)
by Giov 6/24/2012 2:03:46 PM(UTC)
Whirpool Dryer making grinding noise (Dryer Repair)
by mainely 10/16/2011 9:22:53 AM(UTC)
whirpool dryer (Dryer Repair)
by ziggolf 9/5/2011 11:53:12 AM(UTC)
whirpool dryer won't tumble (Dryer Repair)
by ksmaciejewski 3/2/2011 6:40:57 AM(UTC)
Whirpool Dryer not heating (Dryer Repair)
by sunedazekkc 2/23/2011 9:59:33 AM(UTC)
by shirleyschysm 1/13/2011 4:44:30 PM(UTC)
Whirpool dryer not drying!! (Dryer Repair)
by Kim72 11/1/2010 2:18:05 PM(UTC)
whirpool dryer runs for awhile and shuts off (Dryer Repair)
by j moehlenkamp 9/16/2010 9:57:43 AM(UTC)
Whirpool Dryer, Model Ler8648pw1, Does Not Provide Heat (Dryer Repair)
by Tomas13 4/27/2010 3:03:34 PM(UTC)
Whirpool dryer won't light (Dryer Repair)
by stinky5759 2/18/2010 3:30:08 PM(UTC)
Whirpool dryer heating problem (Dryer Repair)
by windsordan 7/30/2009 7:25:42 AM(UTC)
