npcharlotte
#1 Posted : Saturday, June 20, 2009 8:04:32 AM(UTC)
npcharlotte
Water will not drain and I'm not sure what I should do. I would really appreciate any help you could give me with me. --Thanks
#2 Posted : Sunday, June 21, 2009 2:40:09 AM(UTC)
Replacement parts for GE GSD2000J01WW | AppliancePartsPros.com
I am assuming it washes OK
First remove the kick plate.
Is the pump running when it should be draining?
Is The solenoid (Wash/drain) pulling down when it should be draining?
Left hand side attached to the pump housing.
If yes then you probably have a blocked drain hose or house drain blockage.
Undo the drain hose at the sink, often stuff can collect where the hose fits over the drain fitting and cause a plug.
If OK. Try to drain it into a pail. Besure to hold the hose there firmly and put a rag/towel over the top of the pail or you will nhane water everywhere.
Here is a goods site for basic repair help
http://www.applianceaid.com/dishwash.html
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
GE Dishwasher will not drain (Dishwasher Repair)
by langa1975 8/28/2009 6:01:40 AM(UTC)
2 year old GE Dishwasher Will Not Drain. (Dishwasher Repair)
by gmguy01 3/21/2009 9:20:48 PM(UTC)
