I'm Having An Issue With An Old Fridge. The Thermostat Is Not Reading Right. On Level 3 It Starts Freezing Everything. On 2 Things Start Spoiling. I Git A Bad Reading Off Of The Thermostat And Got The Part To Replace It. How Do I Replace It Properly?
If you are sure you got the original factory service part, the thin capillary tube must be routed just where the old one was.
