djohns64
#1 Posted : 16 years ago
djohns64
The ice maker of my side by side refrigerator will not work. The water dispenser works fine. I defrosted the coil in the back of the freezer and turned the freezer back on. But still it will not take on water or go through any cycles. Can you help me?:confused:
woodchuckie
#2 Posted : 16 years ago
woodchuckie
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear and not iced up at the fill tube. If it fills the water mold, see if it starts cycling when it freezes.
djohns64
#3 Posted : 16 years ago
djohns64
Tried to switch the wires on inlet valve, but they where not the same and was not able to switch them.
Any idea what I should do?:confused:
#4 Posted : 16 years ago
Just hold them on and have someone hit the water dispenser, the mold should fill up in 9 seconds.
If ok, measure the freezer temperature, must be below 15 degrees for mold thermostat to work.
Ice maker does not work (Refrigerator & Freezer Repair)
by Vcrepy 10 years ago
Ice Maker Does Not Work (Refrigerator & Freezer Repair)
by Hrosenthal 11 years ago
Ice Maker Does Not work, Water Spews Out (Refrigerator & Freezer Repair)
by ajordanxi 13 years ago
G.E. Refrigerator Ice Maker Does Not Work (Refrigerator & Freezer Repair)
by g8tkeeper 15 years ago
Whirlpool Refrig ice maker does not work (Refrigerator & Freezer Repair)
by kkiger 15 years ago
by dodiedodienhutto 16 years ago
