jnibley
#1 Posted : Friday, June 19, 2009 9:11:29 AM(UTC)
jnibley
dishwasher makes a loud howling noise that progressively is getting louder. washer works fine but noise is getting worse.
#2 Posted : Friday, June 19, 2009 3:24:26 PM(UTC)
You can find some useful information and/or instructions from one of our previous posts: http://forum.appliancepartspros...e-during-wash-cycle.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU1200XTLB0 | AppliancePartsPros.com
iucpa
#3 Posted : Saturday, November 13, 2010 1:05:13 PM(UTC)
iucpa
Can you help guide me through how to access the motor? I have a similar problem - loud howling noise - disassembled everything I could from the inside and cleaned it all out, but still making almost a grinding noise, so I'm not sure what else to check out.
Thank you!
#4 Posted : Monday, November 15, 2010 3:54:21 PM(UTC)
Thank you!
What is the complete model number of the dishwasher?
ED110u812
#5 Posted : Monday, November 28, 2011 5:08:03 PM(UTC)
ED110u812
How do I get to chopper? I am having the same noise problem on our Whirlpool GU1200XTLB0
#6 Posted : Monday, November 28, 2011 5:29:20 PM(UTC)
The instructions are attached to the reply.
File Attachment(s):
How to replace pump & motor.pdf (1,122kb) downloaded 29 time(s).
ED110u812
#7 Posted : Monday, November 28, 2011 6:48:21 PM(UTC)
ED110u812
That worked and I found what shaft holding the chopper and screen was broken. Can you tell me what part that would be for my whirlpool GU1200XTLB0?
#8 Posted : Monday, November 28, 2011 11:22:32 PM(UTC)
sPeCiaL eD
#9 Posted : Wednesday, December 14, 2011 12:13:30 PM(UTC)
sPeCiaL eD
I've followed the steps of removal but can't get the inlet protector removed... Help!!!:confused:
sPeCiaL eD
#10 Posted : Wednesday, December 14, 2011 12:28:49 PM(UTC)
sPeCiaL eD
Disregard, got it. I ended up using a Paint can opener tool to snag under the edge near the screw and it finally popped up!
