fredcroy
#1 Posted : Tuesday, December 6, 2011 2:19:31 PM(UTC)
fredcroy
Called APP & stated I had a E1 F2 error code. Customer Service stated I needed to replace my contol board. It arrived today, I installed it. Started it up PF came on I hit start button, it went off. In less than 60 seconds the E1 F2 error code came on. Help
ApplianceJunk
#2 Posted : Tuesday, December 6, 2011 2:29:37 PM(UTC)
ApplianceJunk
If you have not seen it already here is the tech sheet for your oven. Maybe it will help.
I would maybe check the ribbon cable from the keypad to make sure it's clean and making a good connection with the control board.
File Attachment(s):
Tech Sheet - 4451879.pdf (481kb) downloaded 22 time(s).
