Called APP & stated I had a E1 F2 error code. Customer Service stated I needed to replace my contol board. It arrived today, I installed it. Started it up PF came on I hit start button, it went off. In less than 60 seconds the E1 F2 error code came on. Help
Hi, If you have not seen it already here is the tech sheet for your oven. Maybe it will help. I would maybe check the ribbon cable from the keypad to make sure it's clean and making a good connection with the control board.
