AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't drain and is making a humming noise
So my washer stopped the other day. It's full of water and won't drain, also when I pull the knob it makes a humming sound. I just replaced the timing control thinking that was it... and it doesn't seem to be the problem, still the same noise. Any idea's? Thx.
Could be something stuck in the water pump.
Can you post the model number for us?
Thanks,
I could not find anything on that model number, are you sure it's correct?
Can you tell were the humming sound is coming from?
It sounds like its coming from the timer, that I just replaced. And as far as I know that is the correct model #. They found the part using that #.
Washer Repair
