Echcaroff
#1 Posted : Tuesday, December 6, 2011 1:36:57 PM(UTC)
Echcaroff
So my washer stopped the other day. It's full of water and won't drain, also when I pull the knob it makes a humming sound. I just replaced the timing control thinking that was it... and it doesn't seem to be the problem, still the same noise. Any idea's? Thx.
ApplianceJunk
#2 Posted : Tuesday, December 6, 2011 1:49:40 PM(UTC)
ApplianceJunk
Could be something stuck in the water pump.
Can you post the model number for us?
Thanks,
Echcaroff
#3 Posted : Tuesday, December 6, 2011 5:31:49 PM(UTC)
Echcaroff
Roper RAX232PQ0
ApplianceJunk
#4 Posted : Tuesday, December 6, 2011 5:45:09 PM(UTC)
ApplianceJunk
I could not find anything on that model number, are you sure it's correct?
Can you tell were the humming sound is coming from?
Echcaroff
#5 Posted : Tuesday, December 6, 2011 7:10:08 PM(UTC)
Echcaroff
It sounds like its coming from the timer, that I just replaced. And as far as I know that is the correct model #. They found the part using that #.
