Kcubed
#1 Posted : Wednesday, June 17, 2009 11:32:01 AM(UTC)
Kcubed
We are getting lots and lots of frost in the ice maker shute...I clean it out and it comes back. All systems seem to be running fine when we ran a systems check. However, we have noticed one day there was some condensation on the fridge wall(directly against the freezer) and also noticed that there seems to be a seal/seam coming apart on the ceiling of the freezer. After putting some foam to 'cover' the seam very temporarily, the condensation is gone from the fridge, the freezer is not running as much however still LOTS of frost in the ice maker shute. How do we fix the freezer seam???? And could that be the only thing wrong??
Thanks very much inadvance.
woodchuckie
#2 Posted : Wednesday, June 17, 2009 11:57:45 AM(UTC)
woodchuckie
Make sure the door flap is closing all the way. Could have broken spring or hinge.
Kcubed
#3 Posted : Thursday, June 18, 2009 2:54:50 PM(UTC)
Kcubed
The flap is closing all the way... Still LOTS of frost. Could it be the seal on the ceiling of the freezer that seems to have drooped a bit? All other seals are fine and the ice maker is off so we know it is not a faulty filling of water. Thanks again in advance.
