We are getting lots and lots of frost in the ice maker shute...I clean it out and it comes back. All systems seem to be running fine when we ran a systems check. However, we have noticed one day there was some condensation on the fridge wall(directly against the freezer) and also noticed that there seems to be a seal/seam coming apart on the ceiling of the freezer. After putting some foam to 'cover' the seam very temporarily, the condensation is gone from the fridge, the freezer is not running as much however still LOTS of frost in the ice maker shute. How do we fix the freezer seam???? And could that be the only thing wrong?? Thanks very much inadvance.
Make sure the door flap is closing all the way. Could have broken spring or hinge.
Originally Posted by: woodchuckie  Make sure the door flap is closing all the way. Could have broken spring or hinge. The flap is closing all the way... Still LOTS of frost. Could it be the seal on the ceiling of the freezer that seems to have drooped a bit? All other seals are fine and the ice maker is off so we know it is not a faulty filling of water. Thanks again in advance.
