AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Motor Seal Kit - replace ? - Maytag quiet series 300
I took our dishwasher to the local appliance shop for them to find the problem as it was leaking, not an obvious diagnosis for me. They called - the motor seals need replaced with a motor seal kit. They want $260 for the repair. A new one is $430. The part is $ 60, see below part: Here is the link to the part: Part number: AP4365097
Question: Is it somewhat easy to replace these seals? I'm pretty handy, the dishwasher is out and dry. Thanks.
I agree parts-wise it looks pretty easy. I guess I should have asked a little more specifically are the seals easy to get to and get out and the new ones to get back in. Also, it looks as though there is a shaft of some sort, is that pressed on to a spindle with splines?!?!
Hi magic
Yep, been around for awhile, just have not been posting much here recently. Hope to be a bit more active here now.
Dishwasher Repair
