CPreston
#1 Posted : Tuesday, June 16, 2009 3:48:37 PM(UTC)
CPreston
The water will filll up when the washer is turned on but will not shut off on it's own, instead, it will overflow. What is that part that is messing up?:) Please contact ASAP
applianceman
#2 Posted : Tuesday, June 16, 2009 3:55:20 PM(UTC)
applianceman
If you have to cut the water off to stop the water flow the water inlet valve is bad and needs replacing. If turning the washer off stops the water flow there is something wrong with the water level control such as the tube that runs from the water level control is stopped up or has came loose or the water level switch is bad.
Clothes Washer Repair Guide
CPreston
#3 Posted : Tuesday, June 16, 2009 4:19:18 PM(UTC)
CPreston
Thank you so much... my next question would be how do you put the back back on the washer machine or is there a website I can go to to see how to do this?
applianceman
#4 Posted : Tuesday, June 16, 2009 6:07:28 PM(UTC)
applianceman
The back of your washer is not meant to be taken off, to replace any parts. This link will help in disassembling your washer Whirlpool Washer Disassembly Guide
Water not shutting off (Washer Repair)
by tmiller791@cox.net 6/18/2009 4:32:34 PM(UTC)
