riccam
#1 Posted : Tuesday, June 16, 2009 9:52:49 AM(UTC)
riccam
freezer is fine i changed the thermostat still same problem model is ksrs25ilbl01 and can not locate defrost timer can u tell me where it is or if it is electronic doesnt seem like the fridge ever stops running or cycles and can u give me the part # for defrost timer thanks
#2 Posted : Tuesday, June 16, 2009 11:42:22 AM(UTC)
Perform the troubleshooting as instructed in the Tech sheets and post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRS25ILBL01 | AppliancePartsPros.com
riccam
#3 Posted : Tuesday, June 16, 2009 9:23:25 PM(UTC)
riccam
i completed all the test first 2 green lights they rest seem to go on and run the only thing i find is the air baffle makes a clicking noise when that test is run thanks
