freezer is fine i changed the thermostat still same problem model is ksrs25ilbl01 and can not locate defrost timer can u tell me where it is or if it is electronic doesnt seem like the fridge ever stops running or cycles and can u give me the part # for defrost timer thanks
Originally Posted by: Gene  i completed all the test first 2 green lights they rest seem to go on and run the only thing i find is the air baffle makes a clicking noise when that test is run thanks
