Lendoe
#1 Posted : Friday, December 21, 2007 4:55:51 AM(UTC)
Lendoe
It's a side by side refrig. Any ideas on what could be causing ice to be forming on the back wall?
kawfeeman
#2 Posted : Friday, December 21, 2007 4:59:11 AM(UTC)
kawfeeman
check out the actual evaporator coil .. see if it is completely covered with ice or not ? could have a defrost problem or evaporator fan motor problem as well ? and in some cases , it might be even a compressor problem if there is just some ice where the cap tube meets the evaporator ?
