actionguns
#1 Posted : Monday, June 15, 2009 10:32:17 AM(UTC)
actionguns
My Maytag had previously broken a belt and shattered the idler pully wheel. I replaced both. Now The unit shut down with the smell of something burning....obviously the motor overload protector because it works now. I want to know where the binding is likely happening...brake? misaligned Idler pulley arm? Any help would be appreciated.
#2 Posted : Tuesday, June 16, 2009 5:40:23 PM(UTC)
Remove the belt from the transmission pulley and check how freely the transmission pulley is moving in both directions. Post the results.
actionguns
#3 Posted : Friday, June 19, 2009 11:59:25 AM(UTC)
actionguns
ok, this weekend i'll do just that. i was told that it may be the motor pulley thats plastic and fails. and i was also told that since whirlpool bought out maytag that you can no longer buy just the pulley?
