fobillw
#1 Posted : Sunday, June 14, 2009 4:12:02 PM(UTC)
fobillw
Dishwasher won't drain. No problem for many years. When the control panel calls for drain it just makes a click and then nothing.
Drain tube seems to be correctly routed above disposer connection. It drains out when I disconnected at disposer and lowered the line below the drain.
I see that under the dishwasher there is some sort of ring that snaps into place. If I indo that will the whole motor assembly drop out?
How do I check for a plugged impeller or pump? Any other suggestions? How do you remove the pump?
Thanks for any help. I couldn't find this question answered.
Scott
fobillw
#2 Posted : Sunday, June 14, 2009 5:39:33 PM(UTC)
fobillw
Full model is: MDB9100AWW Ser# 15325312YF
I put everything back together and tried to drain it again. The motor starts for just an instant but won't continue to run, as if the run winding is not connected after the start winding drops out. Is there a test for that?
I would still like to know how to drop the entire pump/motor unit without ruining seals. does the "locking" ring hold it in position and if I pull the spray arm it will all drop out the bottom?
Thanks,
Scott
#3 Posted : Monday, June 15, 2009 4:47:43 PM(UTC)
Originally Posted by: fobillw Go to Quoted Post
..It drains out when I disconnected at disposer and lowered the line below the drain....
Scott,
Did the water flow out by itself or the pump was running at this time?
You can access the drain impeller from the top of the pump by removing the lower spray arm and the top cover.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDB9100AWW | AppliancePartsPros.com
fobillw
#4 Posted : Monday, June 15, 2009 8:17:11 PM(UTC)
fobillw
Gene: Thanks for the reply. I can't really tell which parts come off to get to the impeller.
As noted in my second post, the motor starts but doesn't run. The water was drained out at that point after I lowered the drain hose below the pump. Will the pump not run if the water is drained? As in start for an instant but not run with no water? I didn't try putting some water back in.
To remove the top cover do I take out all of the #5 screws around the perimiter of part #4 to look inside to see if something got sucked into the pump? I removed 32, 34, 1 and 33. As I recall maybe 36 just lifts up.
I will look tomorrow when I am back at the house.
have a great day!
Scott
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
by av0612 8/6/2014 4:42:36 PM(UTC)
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
