haggis2
#1 Posted : Saturday, June 13, 2009 6:40:29 PM(UTC)
haggis2
I just replaced my ice maker in my GE Side-by-Side. The old unit,Part number 04FH1 had an adjustment where you could change the amount of time the fill valve stayed open, imporving the size of the cubes. I replaced it with GE WR30X10093 unit. The cubes are small, but there were no inctruction of how to increase the cube size. Does anyone know if this unit can be adjusted?
woodchuckie
#2 Posted : Saturday, June 13, 2009 7:17:22 PM(UTC)
woodchuckie
Look behind the plastic end cover for and adjustment.
as3usna
#3 Posted : Friday, February 19, 2010 12:43:29 PM(UTC)
as3usna
I just replaced the same model ice make in my 15 year old profile, but the ice cubes are slow, and thin shells mostly. There are some full cubes, but again they are small. I guess each time it cycles I get only about 3-4 cubes. I have confirmed level (although difficult to accomplish with support system. The temperature in the freezer section is minimum 0 deg. Can I adjust the water dispensed to the tray. Where is the adjustment?
Guest
#4 Posted : Monday, June 24, 2024 8:20:03 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Is there an adjustment for cube size on GE french door refrigerator with ice maker at top of left door
Guest
#5 Posted : Monday, June 24, 2024 8:30:37 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Is there an adjustment for cube size on GE french door refrigerator with ice maker at top of left door?
applianceaid1
#6 Posted : Tuesday, June 25, 2024 7:58:22 PM(UTC)
applianceaid1
Canada
Was thanked: 10 time(s) in 10 post(s)
**Is there an adjustment for cube size on GE french door refrigerator with ice maker at top of left door?**
Model#?
https://www.applianceaid.com/model-number.php Some model# helps.
jeff sr.
Appliance Repair Aid
