I just replaced my ice maker in my GE Side-by-Side. The old unit,Part number 04FH1 had an adjustment where you could change the amount of time the fill valve stayed open, imporving the size of the cubes. I replaced it with GE WR30X10093 unit. The cubes are small, but there were no inctruction of how to increase the cube size. Does anyone know if this unit can be adjusted?
Look behind the plastic end cover for and adjustment.
I just replaced the same model ice make in my 15 year old profile, but the ice cubes are slow, and thin shells mostly. There are some full cubes, but again they are small. I guess each time it cycles I get only about 3-4 cubes. I have confirmed level (although difficult to accomplish with support system. The temperature in the freezer section is minimum 0 deg. Can I adjust the water dispensed to the tray. Where is the adjustment?
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Is there an adjustment for cube size on GE french door refrigerator with ice maker at top of left door
Rank: Guest
Groups: Guests
Is there an adjustment for cube size on GE french door refrigerator with ice maker at top of left door?
Joined: 5/12/2024(UTC) Posts: 0  Location: Ontario Was thanked: 10 time(s) in 10 post(s)
