nfc east
#1 Posted : Saturday, June 13, 2009 1:17:23 PM(UTC)
nfc east
gas dryer will not get hot but it will timble
sidfink43
#2 Posted : Sunday, June 14, 2009 3:14:33 PM(UTC)
sidfink43
You are going to need to open it up and check the thermal fuses/thermostats
This service manual will show you how
http://www.servicematters.com/m...ibrary/docs/16023020.pdf
Let us know what you find out.
kayakcrzy
#3 Posted : Sunday, June 14, 2009 5:48:47 PM(UTC)
kayakcrzy
Take the 2 screws off of the bottom panel. Unplug the dryer. Now lay on your stomach, and in the bottom back left hand corner is the element. There is a 5/16s screw on each side, for you to take off, and the element will slide down and out of its place. The wires are long enough for you to bring the whole assembly to the front. Tom
