gas dryer will not get hot but it will timble
Originally Posted by: sidfink43  Take the 2 screws off of the bottom panel. Unplug the dryer. Now lay on your stomach, and in the bottom back left hand corner is the element. There is a 5/16s screw on each side, for you to take off, and the element will slide down and out of its place. The wires are long enough for you to bring the whole assembly to the front. Tom
