Hello, I bought an oven replacement control pad and could change everything but the DLB relay. It has two red wires and no other marks. The schematic calls them p3-1 and p3-2. They are plugged into the back of a black relay 1 vertical and one horizontal. The replacement has an orange relay with L2 and DLB for the two wires. Could you please tell me what goes where?
If you did not labeled the wires prior to remove them then you have to track them. According to the wiring diagram the wire which should be connected to the "P3-1" terminal is the incoming power from the "L2" terminal and the wire which should be connected to the "P3-2" terminal is the outgoing power to the heating elements. Gene.
Originally Posted by: Gene  If you did not labeled the wires prior to remove them then you have to track them. According to the wiring diagram the wire which should be connected to the "P3-1" terminal is the incoming power from the "L2" terminal and the wire which should be connected to the "P3-2" terminal is the outgoing power to the heating elements. Gene. I didn't remove them for that reason. Is there an easier way now to switch without tracing the wires?
Thanks Gene, I'll try it tomorrow. Let you know how it comes out.
I connected the P3-1 wire to the L2 terminal. The other terminal had DLB on it. That is where I connected P3-2 wire. Is that correct? There was no other place to connect it.
