James Barrentine
#1 Posted : Friday, June 12, 2009 8:31:29 AM(UTC)
James Barrentine
Hello, I bought an oven replacement control pad and could change everything but the DLB relay. It has two red wires and no other marks. The schematic calls them p3-1 and p3-2. They are plugged into the back of a black relay 1 vertical and one horizontal. The replacement has an orange relay with L2 and DLB for the two wires. Could you please tell me what goes where?
#2 Posted : Friday, June 12, 2009 1:22:49 PM(UTC)
If you did not labeled the wires prior to remove them then you have to track them. According to the wiring diagram the wire which should be connected to the "P3-1" terminal is the incoming power from the "L2" terminal and the wire which should be connected to the "P3-2" terminal is the outgoing power to the heating elements.
James Barrentine
#3 Posted : Friday, June 12, 2009 5:53:28 PM(UTC)
James Barrentine
I didn't remove them for that reason. Is there an easier way now to switch without tracing the wires?
James Barrentine
#4 Posted : Friday, June 12, 2009 6:32:29 PM(UTC)
James Barrentine
James Barrentine
#5 Posted : Friday, June 12, 2009 7:58:05 PM(UTC)
James Barrentine
Thanks Gene, I'll try it tomorrow. Let you know how it comes out.
James Barrentine
#6 Posted : Saturday, June 13, 2009 7:27:28 AM(UTC)
James Barrentine
I connected the P3-1 wire to the L2 terminal. The other terminal had DLB on it. That is where I connected P3-2 wire. Is that correct? There was no other place to connect it.
