pama59
#1 Posted : Sunday, November 27, 2011 5:47:03 AM(UTC)
pama59
My batch feed garbage disposal will not turn off. It seems whatever connections are made when the stopper is inserted are 'stripped'. The stopper itself seems to be in good shape. In order to operate now, I have to unplug it until I need to use it. Which replacement parts do I need? :confused:
Garbage disposal not working (Garbage Disposer Repair)
by Guest 9/25/2021 4:06:35 AM(UTC)
New Garbage Disposal sparks underneath when switch is thrown (Garbage Disposer Repair)
by john flavia 12/14/2015 8:05:13 AM(UTC)
leaking garbage disposal (Garbage Disposer Repair)
by gesche444 8/11/2014 3:23:39 PM(UTC)
Monarch Garbage Disposal (Garbage Disposer Repair)
by willie2840 7/20/2013 1:40:26 PM(UTC)
GE garbage disposal jammed from potato skins (Garbage Disposer Repair)
by Clifford_boyson_iowa 1/9/2013 8:47:55 PM(UTC)
Garbage Disposal not closing (Garbage Disposer Repair)
by avidteacher1 6/26/2012 8:41:42 AM(UTC)
by jakester3 6/12/2012 5:43:27 PM(UTC)
Leaking Garbage Disposal (Garbage Disposer Repair)
by newelldj2 4/9/2012 12:40:32 PM(UTC)
garbage disposal died - won't do anything (Garbage Disposer Repair)
by mindiloo 1/31/2012 5:36:42 PM(UTC)
Stuck garbage disposal (Garbage Disposer Repair)
by DonnieMo 1/7/2012 11:24:18 AM(UTC)
Garbage disposal leaking at yhe boiiom when water is turned on (Garbage Disposer Repair)
by dsloss1 11/13/2011 11:47:44 AM(UTC)
Garbage disposal problem (Garbage Disposer Repair)
by jnfica 7/21/2011 7:19:58 PM(UTC)
Leaky garbage disposal (Garbage Disposer Repair)
by Tippsy 6/22/2011 4:59:19 AM(UTC)
garbage disposals (Garbage Disposer Repair)
by shelterpup 1/4/2011 7:42:39 PM(UTC)
kenmore garbage disposal internal leak (Garbage Disposer Repair)
by bill5506 12/27/2009 8:12:02 AM(UTC)
