electric dryer won't start only makes buzzing sound when the start sw.is activated
Have a friend engage the door switch, and then press the start switch while you turn the drum to see if you can start it. If you can the likely problem is that your motor is bad and will have to be replaced.
Good luck, keep us posted.
