cobra9646
#1 Posted : Tuesday, December 18, 2007 11:58:11 AM(UTC)
cobra9646
I have a admiral capacity plus lnc7766a00 . dryer works then stops before cycle is over. If i try to restart it buzzes, if wait about 5 minutes it will run for 10-15 min then same problem.
kawfeeman
#2 Posted : Wednesday, December 19, 2007 5:20:49 AM(UTC)
kawfeeman
sounds like a bad motor .... ( just as a FYI, check to make sure venting is clean / clear .. )
phays1955
#3 Posted : Monday, October 20, 2008 6:37:28 PM(UTC)
phays1955
Originally Posted by: cobra9646 Go to Quoted Post
I have an admiral capacity plus lnc7766a00 . dryer works then stops before cycle is over. If i try to restart it buzzes, if wait about 5 minutes it will run for 10-15 min then same problem.
It heats up, the timer keeps ticking down at times it runs longer than other times
phays1955
#4 Posted : Monday, October 20, 2008 6:39:56 PM(UTC)
phays1955
My son opened the machine, front and back and vacuumed it clean
shawn1991
#5 Posted : Tuesday, October 21, 2008 6:35:08 AM(UTC)
shawn1991
i would call out the timer but that is just me..
