I have a admiral capacity plus lnc7766a00 . dryer works then stops before cycle is over. If i try to restart it buzzes, if wait about 5 minutes it will run for 10-15 min then same problem.
sounds like a bad motor .... ( just as a FYI, check to make sure venting is clean / clear .. )
Originally Posted by: cobra9646  I have an admiral capacity plus lnc7766a00 . dryer works then stops before cycle is over. If i try to restart it buzzes, if wait about 5 minutes it will run for 10-15 min then same problem. It heats up, the timer keeps ticking down at times it runs longer than other times
My son opened the machine, front and back and vacuumed it clean
i would call out the timer but that is just me..
