I need toremove the Dryer Drum and was told to remove door lift drum and pull, but having no luck. Any suggestions?
you will have two screws where the lint screen is ,remove them , then with a slot screw driver at front insert at either corner and pry up , you will see two screws at left +right securin g front panel .remove them then pull panel towards you +up to detach from bottom clips,put panel along side of dryer.do not detach wires. remove belt at bottom back at right from tension pulley .remove drum
