Matt C
#1 Posted : Tuesday, December 18, 2007 11:49:17 AM(UTC)
Matt C
Groups ready for retrieval: Registered
I need toremove the Dryer Drum and was told to remove door lift drum and pull, but having no luck. Any suggestions?
misterfixall
#2 Posted : Thursday, December 20, 2007 6:03:37 PM(UTC)
misterfixall
you will have two screws where the lint screen is ,remove them , then with a slot screw driver at front insert at either corner and pry up , you will see two screws at left +right securin g front panel .remove them then pull panel towards you +up to detach from bottom clips,put panel along side of dryer.do not detach wires. remove belt at bottom back at right from tension pulley .remove drum
