reed0115
#1 Posted : Tuesday, June 9, 2009 4:14:26 PM(UTC)
reed0115
The stove works fine if I am only using one burner. If I try to use two burners simultaneously, the second one will not light unless I hold a match to it (the pilot IS on) and the flame of the first burner is drastically reduced when I try to use a second burner. Also, if I am using a top burner, the oven will not work. There are a series of small "explosions" as it tries to ignite.
I think the problem is the gas regulator. It was made by the now-defunct Harper Wyman Company. I have been unable to get a part number from Whirlpool (the stove is about 40 years old), but I am hoping someone will know where I can get the gas regulator for the 31DA-7 stove, or will now of a substitute part that will work. It is not an electric regulator.
Thank you.
Dan O.
#2 Posted : Wednesday, June 10, 2009 6:50:01 PM(UTC)
Dan O.
The replacement regulator for that model is available at the following link:
LINK > Magic Chef 31DA-7 Regulator
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
reed0115
#3 Posted : Thursday, June 11, 2009 12:19:54 PM(UTC)
reed0115
Thanks for that, Dan. I will give it a shot and see how it goes. Just out of curiosity, would any non-electric gas stove regulator work, as long as it was appropriate for use with natural gas?
Reed
Dan O.
#4 Posted : Friday, June 12, 2009 8:01:38 PM(UTC)
Dan O.
JFYI. I've never heard of an electric gas regulator.
Quote:
would any gas stove regulator work, as long as it was appropriate for use with natural gas?
.. and had the same size tubing connections and fit the particular installation.
Probably.
Dan O.
=D~~~~~~
