My ice maker does not get filled with water (otherwise works through the usual cycles) i replaced it with new one (kept the same wires) wit same results. Should i replace the water valve?
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
