I am try find the location of the Defrost timer and thermostat on my fridge. I looked at the schematics, i think the timer is on the bottom right hand side behind the kick plate. But i dont know how to take out. is this really the right area. Also, where can i find the defrost thermostat? :o
Hi Woodchuckie,
I removed some of the screw. If i remove all will the black box come out with the timer?
And for the defrost thermostat, i cant tell on the diagram where i would access. will i do it from the back or from the refrigerator in the front. NOt sure by looking at the diagram.
Originally Posted by: johnnyram  Hi Woodchuckie, I removed some of the screw. If i remove all will the black box come out with the timer? And for the defrost thermostat, i cant tell on the diagram where i would access. will i do it from the back or from the refrigerator in the front. NOt sure by looking at the diagram. I can't tell by the picture for sure. It looks like two screws holding in unless it just clamps in. The defrost thermostat, heater and evaporator are in the freezer behind a panel on the back.
