johnnyram
#1 Posted : Monday, June 8, 2009 8:50:49 AM(UTC)
johnnyram
I am try find the location of the Defrost timer and thermostat on my fridge. I looked at the schematics, i think the timer is on the bottom right hand side behind the kick plate. But i dont know how to take out. is this really the right area.
Also, where can i find the defrost thermostat?
:o
woodchuckie
#2 Posted : Monday, June 8, 2009 1:02:56 PM(UTC)
woodchuckie
Part 14 diagram 7 is your defrost thermostat. It's inline with your heater.Replacement parts for WHIRLPOOL GB2SHKXKQ00 | AppliancePartsPros.com
Your timer is accessed from the front behind the kick panel which is at the floor you remove it by removing the screws holding it to a bracket.
johnnyram
#3 Posted : Monday, June 8, 2009 1:21:43 PM(UTC)
johnnyram
Hi Woodchuckie,
I removed some of the screw. If i remove all will the black box come out with the timer?
And for the defrost thermostat, i cant tell on the diagram where i would access. will i do it from the back or from the refrigerator in the front. NOt sure by looking at the diagram.
woodchuckie
#4 Posted : Monday, June 8, 2009 4:56:41 PM(UTC)
woodchuckie
Originally Posted by: johnnyram Go to Quoted Post
Hi Woodchuckie,
I can't tell by the picture for sure. It looks like two screws holding in unless it just clamps in.
The defrost thermostat, heater and evaporator are in the freezer behind a panel on the back.
