grhodes
#1 Posted : Monday, December 17, 2007 2:42:52 PM(UTC)
grhodes
machine starts spin cycle ok runs up to speed for about 1 minute
then slows down a minute then speeds back up?????
kawfeeman
#2 Posted : Tuesday, December 18, 2007 5:12:53 AM(UTC)
kawfeeman
does this occur while there is still water in there ?
grhodes
#3 Posted : Tuesday, December 18, 2007 6:11:58 AM(UTC)
grhodes
no the tub is empty of all water, just the wash load is in there!
#4 Posted : Tuesday, December 18, 2007 8:51:03 AM(UTC)
Check for a loose belt, should be fairly tight. If ok, if you have an amprobe, check the motor current while it's doing it's weird thing.
If current is stable, you might have bad spin bearings and a slipping clutch, check the clutch housing for heat.
Maytag Neptune Washer Clutch Replacement (Washer Repair)
by helplessm355 4/16/2015 5:22:16 PM(UTC)
GE washer clutch grinding on clutch spring clip (Washer Repair)
by fixler1 8/11/2013 5:29:04 PM(UTC)
washer clutch replacement (Washer Repair)
by mlovett22 6/8/2013 11:56:58 AM(UTC)
Washer clutch (Washer Repair)
by Mph08si 3/7/2012 9:14:38 AM(UTC)
Washer clutch? brake? transmission? help please. (Washer Repair)
by mcompton1973 1/10/2012 2:17:32 PM(UTC)
GE Washer clutch needs replacing? (Washer Repair)
by Tami Ragusa 9/1/2011 12:01:42 PM(UTC)
Whirlpool Washer clutch (Washer Repair)
by tapioca 12/12/2010 1:52:55 AM(UTC)
Whirlpool Top Load Washer Clutch Ring Retainer (Washer Repair)
by teddy99520 6/28/2009 1:23:21 PM(UTC)
maytag fav6800aww washer clutch replacement (Washer Repair)
by pandsshearer 3/5/2009 11:44:36 AM(UTC)
Kenmore Laundry Center - Washer Clutch Question... (Washer Repair)
by ascdesigns 1/2/2008 7:32:58 AM(UTC)
