HOW CAN GET TO THE BLOWER MOTOR TO TEST IT? ARE THERE ANY LIMIT OR SAFETY SWITCHES TO PREVENT IT FROM COMING ON? THE IGNITER LIGHTS AND THE DRUM SPINS, NO AIR. I TOOK THE BACK OFF i CAN SEE THE FLYWHEEL, IT IS NOT SPINNING, AND IT SEEMS TO SPIN FREELY. wHAR WOULD CAUSES THIS?
You need to pull the front off and the drum, you will probably find a belt has fallen off the blower pulley and bad blower bushings.
