A correction to my post from yesterday. The turntable is skipping once every revolution. I am still looking for advice as to what could be causing this problem, and how to fix it.
Remove the glass tray. Pull out the coupling (#15 on the diagram) and check it for a crack(s). If there is nothing wrong then replace the turntable motor (#22). - The part number for the coupler is AP4425077 - The part number for the turntable motor is AP4357942Gene.
Thank you, Gene! I gave a twist to the coupler, and it seemed to solve the problem.
