RCDC
#1 Posted : Friday, June 5, 2009 8:37:06 AM(UTC)
RCDC
A correction to my post from yesterday. The turntable is skipping once every revolution. I am still looking for advice as to what could be causing this problem, and how to fix it.
#2 Posted : Friday, June 5, 2009 4:36:13 PM(UTC)
Remove the glass tray. Pull out the coupling (#15 on the diagram) and check it for a crack(s). If there is nothing wrong then replace the turntable motor (#22).
- The part number for the coupler is AP4425077
- The part number for the turntable motor is AP4357942
RCDC
#3 Posted : Tuesday, June 9, 2009 8:06:36 AM(UTC)
RCDC
Thank you, Gene! I gave a twist to the coupler, and it seemed to solve the problem.
Turntable skips (Microwave Repair)
by RCDC 6/4/2009 10:55:31 AM(UTC)
