My Frigidaire washer just quit working. It will not work on any cycle. I checked the breaker box, plugged it in to a different outlet, all of the typical things. I could not find any fuse in the unit. Any other things I can check?
Sean
There is no noise or hum at all. I turn it on and there is nothing.
Sean,
What is the complete model number of the washer?
I think it is FWXB23RG.
Sean
I am thinking it is either the on/off/selection switch or the flow valve. Which one is it more likely to be?
