mickisdaddy
#1 Posted : Friday, June 5, 2009 5:31:18 AM(UTC)
mickisdaddy
My Frigidaire washer just quit working. It will not work on any cycle. I checked the breaker box, plugged it in to a different outlet, all of the typical things. I could not find any fuse in the unit. Any other things I can check?
Sean
mickisdaddy
#2 Posted : Friday, June 5, 2009 5:55:02 AM(UTC)
mickisdaddy
There is no noise or hum at all. I turn it on and there is nothing.
#3 Posted : Friday, June 5, 2009 12:16:05 PM(UTC)
Sean,
What is the complete model number of the washer?
mickisdaddy
#4 Posted : Friday, June 5, 2009 5:39:00 PM(UTC)
mickisdaddy
I think it is FWXB23RG.
Sean
mickisdaddy
#5 Posted : Monday, June 8, 2009 3:45:45 AM(UTC)
mickisdaddy
I am thinking it is either the on/off/selection switch or the flow valve. Which one is it more likely to be?
