es1gt
#1 Posted : Friday, June 5, 2009 4:59:35 AM(UTC)
es1gt
I am looking for a wiring diagram for the Magic Chef Model Number MCBC58DST Beverage Cooler. The thermostat only allows the lowest setting of 39 degree's and has a tolerance of +/- 5 degree so for the most part is is keep my beverages at 44 degree not very tasty on a hot day. I found a temporary thermostat that I will most likely install, but am also wonder if anyone has other thermostat's they would recommend.
#2 Posted : Friday, June 5, 2009 12:02:00 PM(UTC)
The model number you posted does not come up. If this fridge is less than a year old then call the manufacturer for the warranty service. If it's not under the warranty then look for a part number on the thermostat and post it.
wifimoocher
#3 Posted : Thursday, August 22, 2013 8:30:43 AM(UTC)
wifimoocher
I too have a magic chef beverage cooler model MCBC580DBT. I brew beer and want this to be able to get warmer than what it is now. Is there a way to adjust the temp beyond the defaults?
es1gt - If you found a diagram or a way to adjust this contact me.
