I am looking for a wiring diagram for the Magic Chef Model Number MCBC58DST Beverage Cooler. The thermostat only allows the lowest setting of 39 degree's and has a tolerance of +/- 5 degree so for the most part is is keep my beverages at 44 degree not very tasty on a hot day. I found a temporary thermostat that I will most likely install, but am also wonder if anyone has other thermostat's they would recommend.
The model number you posted does not come up. If this fridge is less than a year old then call the manufacturer for the warranty service. If it's not under the warranty then look for a part number on the thermostat and post it.
I too have a magic chef beverage cooler model MCBC580DBT. I brew beer and want this to be able to get warmer than what it is now. Is there a way to adjust the temp beyond the defaults?
es1gt - If you found a diagram or a way to adjust this contact me.
