FrankOC
#1 Posted : Monday, November 21, 2011 9:16:29 AM(UTC)
FrankOC
I purchased a new timer from AppliancePartsPros.com.
Timer part number AP2107583- order number 2212493.
I am having a problem getting the timer dial off so I can remove old timer and replace it with the new one. I don't want to break the dial, and would like some help removing it. Thank you
ceak
#2 Posted : Monday, November 21, 2011 12:43:23 PM(UTC)
ceak
Hi, pull the control panel off to get to the back of the timer and in the center of the timer you will see a pin that needs to be pulled out gentle and that will release the knob.?
Frigidaire Laundry Center Dryer Thermocouple replacement (Dryer Repair)
by Guest 8/26/2022 6:04:09 AM(UTC)
frigidare laundry center (Washer Repair)
by makenna15 8/11/2016 2:15:42 PM(UTC)
Laundry Center (Washer Repair)
by ericjesso1 12/29/2014 10:46:18 AM(UTC)
Frigidaire Laundry Center FUBAR (Washer Repair)
by tommy1673 1/20/2014 10:32:23 PM(UTC)
Laundry Center/stackable washer dryer (Washer Repair)
by ToddWalls 4/1/2013 5:46:36 PM(UTC)
Frigidaire laundry center washer motor just hums for 5 seconds and shuts off (Washer Repair)
by rtlind83 3/8/2013 2:07:34 PM(UTC)
Kenmore laundry center repair (Washer Repair)
by Kleinens 2/20/2013 3:30:37 PM(UTC)
Kenmore laundry center (Dryer Repair)
by waltjski 2/11/2013 12:30:45 PM(UTC)
frigidaire flse72gcs7 gallery laundry center washing machine won't spin (Washer Repair)
by hyperturtle 1/14/2013 8:18:44 PM(UTC)
by Liam250 7/26/2012 7:15:35 AM(UTC)
Electric Dryer on Kenmore Laundry Center won't heat (Dryer Repair)
by JimKl 6/6/2012 7:17:15 PM(UTC)
Frigidaire laundry center need to replace motor of dryer (Dryer Repair)
by suziguzzi 12/22/2011 4:55:43 AM(UTC)
GE Laundry Center diagnostic help needed. (Dryer Repair)
by jwduncan 10/19/2011 5:52:02 AM(UTC)
Frigidaire Laundry Center Dryer Problem (Dryer Repair)
by dee50 6/30/2011 11:25:49 AM(UTC)
Frigidaire Laundry Center (Washer Repair)
by MisterR 6/10/2011 12:37:14 PM(UTC)
