I purchased a new timer from AppliancePartsPros.com. Timer part number AP2107583- order number 2212493. I am having a problem getting the timer dial off so I can remove old timer and replace it with the new one. I don't want to break the dial, and would like some help removing it. Thank you
Hi, pull the control panel off to get to the back of the timer and in the center of the timer you will see a pin that needs to be pulled out gentle and that will release the knob.?
