My washer has been run with an off-balanced load on and off at times. (Someone does not get to it in time to balance the load) It now leaks with a drip to light flow at the bottom of the machine. I think it is due to the 'abusive unbalanced use'. The basket seems to show excessive play as it moves from side to side more than (I think) it used to; and the agitator has about 1 inch of play when I lift up on it. Is this a 'common' problem and... one that I can fix without too much trouble? Thanks, RPaul.
Remove the front panel and tell us where the leak is.
It seems the water is leaking at the base of the tub in the center. If the picture shows; the leak is where part #20 meets the base of the tub. There is a rubber piece there and the water has a 'drip to light flow' at that point. ALSO... I need to fix the loose tub - or so it seems to be more loose than before. Can I just tighten the springs? or is there a 'regular' fix for this? Thanks... RPaul. ![UserPostedImage](http://www.appliancepartspros.com/sect/y/n/i/ynig-hgjjf.gif)
You will need to pull the tub and replace the tub seal and bearing. There is info on this at www.applianceaid.com. just refer to the dependable care washer section. A routine repair, but time consuming. You will need to drive the old sleeve bearing off the tranny housing with a steel rod.
