Food in freezer thaws in defrost cycle. I replaced electrical control per advise in this forum. Problem persists. Help appriciated.
The defrost thermostat prevents the heater from overheating the freezer by breaking the circuit when the temp on the evaporator coils reach 32 degrees. Yours must be defective.
Thanks. Where is the defrost thermostat located? Do you have a part number? Thanks.
