The drain tube on my refregerator seems to be clogged, how do I unclog it? Where is the actual tube located and can I remove it to clean it. I think it starts behind the freezer panel. Any help appreciated. the last advice given to me worked well. Thanks
many times there is ice along with little little pieces of food stuffs stuck in there... if you have the time, you can use warm water with a turkey baster to push water through, S L O W L Y... as you push water in to the cond drain ( in the freezer ) push some in and pull some out .. after several pushes and pulls , change out water w/ fresh warm water ... disconnect power and remove back panel .. beneath evaporator, you should notice the trough...
Thanks for your quick reply, will do and will post my results . Thanks Again
good luck, take your time ....
