Cerch
#1 Posted : Monday, December 17, 2007 6:41:12 AM(UTC)
Cerch
The drain tube on my refregerator seems to be clogged, how do I unclog it? Where is the actual tube located and can I remove it to clean it. I think it starts behind the freezer panel. Any help appreciated. the last advice given to me worked well. Thanks
kawfeeman
#2 Posted : Monday, December 17, 2007 6:49:10 AM(UTC)
kawfeeman
many times there is ice along with little little pieces of food stuffs stuck in there... if you have the time, you can use warm water with a turkey baster to push water through, S L O W L Y... as you push water in to the cond drain ( in the freezer ) push some in and pull some out .. after several pushes and pulls , change out water w/ fresh warm water ... disconnect power and remove back panel .. beneath evaporator, you should notice the trough...
Cerch
#3 Posted : Monday, December 17, 2007 6:55:01 AM(UTC)
Cerch
Thanks for your quick reply, will do and will post my results . Thanks Again
kawfeeman
#4 Posted : Monday, December 17, 2007 6:58:51 AM(UTC)
kawfeeman
good luck, take your time ....
