djwil
#1 Posted : Thursday, June 4, 2009 8:55:44 AM(UTC)
djwil
This unit was running and quit when almost done with a wash. The front panel cycle lites will not lite up, and it will not run, but when you press the on/off button with the door latched you can almost hear the motor try and run (I can here a very quick noise. Don't know if it's the motor or a solenoid. Today I pressed the on/off switch and it started to drain for a few seconds and quit, but the cycle light did not lite up at any time. Any ideas?
Wil
#2 Posted : Thursday, June 4, 2009 1:01:39 PM(UTC)
Sounds like the control module has gone bad. You can use the troubleshooting manual from one of our previous posts: http://forum.appliancepartspros...troubleshoot-manual.html
- The part number for the control module is AP2804247
Here are the breakdown diagrams and Replacement parts for BOSCH SHU4306 UC/06 (FD 7705-7912) | AppliancePartsPros.com
